- Új, bontatlan Kingston FURY 32GB (2x16GB) DDR5 6000MHz CL36 Beast XMP/EXPO - 2 év bolti garival! -
- Dell Latitude 7320 i5-1145G7 16GB 512GB 1 év garancia
- Bomba ár! HP EliteBook 820 G2 - i5-5GEN I 8GB I 256GB SSD I 12,5" FHD I Cam I W10 I Garancia!
- BESZÁMÍTÁS! MSI B450 R5 5600X 32GB DDR4 512GB SSD RX 6700XT 12GB Zalman Z1 Plus Cooler Master 750W
- Intel Core i5 3470 confidential Ivy bridge Quad Core
- Apple iPhone 13 Pro Alpine Green ProMotion 120 Hz, Pro kamerák 128 GB-100%
