.mf
KillHates
#833
Az még nem minden. Ld Anandtech teszt DFI P55 MI-T36-ról:
"All of the above issues have been reported back to DFI who are working on fixes as we speak. The new BIOS will also cap over-current protection to around 90 amps with a maximum VID of 1.40V (currently set to 110 amps). The reason is that onboard power delivery for CPU VCore does not respond kindly to being pushed under heavy loads. We've seen one reported case of a reviewer pushing the board over 3.8GHz with a HT enabled 4 core CPU running stress tests like OCCT and burning out a couple of FETs. Just a heads up to those who are thinking of pushing the MI-T36: it's not designed for it."
- Tápos kibeszélő offtopik
- Fejhallgatós találkozó
- Túl jól fogy az S26, túlóráznia kell a gyártósoroknak
- Villanyszerelés
- Crimson Desert
- Telekom mobilszolgáltatások
- Honor 600 Lite - koffein nélkül
- TCL LCD és LED TV-k
- GYÖNYÖRŰ iPhone 14 Pro Max 128GB Deep Purple-1 ÉV GARANCIA - Kártyafüggetlen, MS3913
- MSI 14 Modern C12M FHD IPS i7-1255U 10mag 16GB 512GB SSD Intel Iris XE Graphics Win11 Garancia
- Inno3D RTX 5070 // Felbontott, új // SZÁMLA // GARANCIA //
- Huawei Watch GT 5 46mm okosóra
- Ritkaság! Csere-Beszámítás! EVGA FTW3 Ultra RTX 3080 10GB GDDR6X Videokártya!
