- ÚJ 32GB DDR4 3200AA Laptop memória
- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- SK Hynix 16GB DDR5 4800Mhz laptop ram több db!
