Archttila
Nos neki itt gurult el az a bizonyos gyogyszer:
I got my Asus Maximus Hero VI few days back. I installed everything correctly and very carefully. Everything went fine about three hours and then Maximus hero VI suddenly just shutsdown. I was just idling on my desktop, temps below 28C, no overclocking, everything on default. I was like WTF, what now? Computer didn't POST at all, fans just spinning. First I thought that my power supply failed, but it was working fine with my previous setup few hours earlier, so I ended up pulling everything off except cpu and cooling, but still same CoDe 00! I wasted hole weekend searching answers from the web and try to fix the problem. Then someone from the overclocking.net forum said that if you get that code 00 error get rid off that board fast, it won't work ever. So I contacted Amazon.uk customer service and explained the situation, they promised full refund and were very sorry for the trouble.So I ended up returning the maximus hero VI, got my money back, bought MSI Mpower Max board, put everything together again, pressed power button and voilà! everything lights up and no problems! No Asus boards in this household ever again.
Jovoheten jo az uj proci. (~szerda) de ugy dontottem, hogy visszakuldom az alaplapot is es rendelek helyette egy MSI z170i -t. Ha minden rendben lesz akkor boldogok leszunk, ha nem, akkor eladok mindent az utolso csavarig!
jo ejt!
ps. Faj a szemem a sok olvasastol
- Mini Pc HP ProDesk 600 G2 G3 G4 /// 6-8. gen //// i3 / i5 /// garancia /// Budapest / MPL / Foxpost
- Garmin USB ANT Stick jeladó eladó
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7500F 32/64GB RAM RTX 5060 Ti 8GB GAMER PC termékbeszámítással
- iPhone 13 mini 128GB Midnight -1 ÉV GARANCIA - Kártyafüggetlen, MS3086, 100% Akkumulátor
- Bontatlan, Sony PS5 PRO Pro 2TB, lemez mentes verzió
