- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- HyperX Fury DDR4 - 3200 - CL16 - 16GB RAM (8GB x 2) RGB
- GIGABYTE B760 GAMING X AX WIFI - Garancia 2027.09.06.
- TP-Link Archer C1200 Wireless Dual Band Gigabit Router v2.0
- Bomba ár! HP ProBook 6560B - i5-2450M I 8GB I 500GB I 15,6" HD I Cam I W10 I Garancia!
- Dell Latitude 7320 i5-1145G7 16GB 512GB 1 év garancia
- BESZÁMÍTÁS! Gigabyte Z37 i5 9600K 16GB DDR4 512GB SSD RTX 2060 Super 8GB Rampage SHIVA ADATA 600W
