Archttila
#32719
Asrock Fatal1ty Z170 Gaming-ITX/ac atom stabilan tartja 4.5Ghz (1.3v nem ingadozik lásd MSI) Az Asus nekem megfőzte a procimat még élek hanyagolom azt a márkát.
Sima liba az 5GHz ha kell... VRM messze jobb mint az Asus-on. hova soroljam...
Hidd el megéri azt a kis pluszköltséget.
The PCH and VRM heat sinks are connected by an 8mm heat sink. Thermal pads are used, and they seem to make very good contact (better than normal) to the PCH and the VRM MOSFETs.
The Fatal1ty Z170 Gaming-ITX/ac has a 6+2 phase VRM for the CPU + iGPU phases, and a linear regulator is used for the VCCSA and VCCIO. Each of these phases gets a 60A power inductor, and there are tantalums used for the output filter. This VRM looks high quality even without removing the heat sinks, but removing the heat sinks (that cool the CPU phases) reveals some high-quality integrated MOSFETs.
Díjakat teszteket olvastad/láttad?
pl. [link] (érdemes végigolvasni)Persze egy Maximus-al nem veheti fel a versenyt, de más ársavban is mozognak.
ASRock's Fatal1ty Z170 Gaming-ITX/ac impressed me, and I am not easy to impress. I usually get worked up quite easily, and I am very picky. I have to tone down my dissatisfaction since most people aren't as harsh as I am. In this case, it was hard for me to find something I did not like about the board, and it just came down to hardware the board is missing that is common on other boards.
Jó sok fejfájástól kímélem meg magamat, ha már ez elején az Asrock mellett teszem le a voksomat.
- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- Apple iPhone 17 Air 256,Új, Bontatlan,36 hónap garanciával
- ÁRGARANCIA!Épített KomPhone i7 14700KF 32/64GB RAM RTX 5080 16GB GAMER PC termékbeszámítással
- Lenovo Tab M10 HD 64GB, Kártyafüggetlen, 1 Év Garanciával
- Apple iPhone 13 Pro 128GB, Kártyafüggetlen, 1 Év Garanciával
- REFURBISHED és ÚJ - Lenovo ThinkPad Ultra Docking Station (40AJ)
pl.
