D.Dani
D.Dani
#52114
Intel has identified an issue that potentially affects the 6th Gen Intel® Core™ family of products. This issue only occurs under certain complex workload conditions, like those that may be encountered when running applications like Prime95. In those cases, the processor may hang or cause unpredictable system behavior. Intel has identified and released a fix and is working with external business partners to get the fix deployed through BIOS.
- Napelem
- Diablo IV
- Google Pixel topik
- Gumi és felni topik
- G.Skill Aegis DDR4 16GB CL16 3200MHz Gaming Series
- Kingston FURY Beast 32GB (2x16GB) DDR4 3200MHz (Beszámítás)
- Kingston FURY Beast RGB 16GB (2x8GB) White RGB Special Edition DDR4 3600MHz CL17 KF436C17BWAK2/16
- Gigabyte FXA-990-UD5 / Beszámítás OK!
- BESZÁMÍTÁS! Asus Sabertooth Z97 Mark 1 alaplap garanciával hibátlan működéssel
- AKCIÓ! Intel Core i9 13900K 24 mag 32 szál processzor garanciával hibátlan működéssel
- Sapphire Nitro+ RX 5700 XT 8GB
- Akció! Apple iMac 19.2 i5-8500 Radeon Pro 560X 4GB 16GB 256GB SSD 21.5" 4K Retina
- HIBÁTLAN iPhone 13 Pro 256GB Sierra Blue-1 ÉV GARANCIA - Kártyafüggetlen, MS4662, 90% AKKSI
- GAMING PC! Ryzen 9 3900X / RX 6700 XT / B450 / 16GB 4000MHz / 500GB NVMe / 750w Gold! BezsámítOK
