- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- GIGABYTE B760 GAMING X AX WIFI - Garancia 2027.09.06.
- ASUS Prime B550M-K alaplap 24 hó gari
- HIBÁTLAN iPhone 15 Pro Max 256GB Blue Titanium -1 ÉV GARANCIA -Kártyafüggetlen, 100% Akkumulátor
- Intel Core i5 3470 confidential Ivy bridge Quad Core
- HIBÁTLAN iPhone 13 mini 128GB Pink -1 ÉV GARANCIA - Kártyafüggetlen, MS3842, 100% Akkumulátor
- 164 - Lenovo Legion Pro 7 (16IRX9H) - Intel Core i9-14900HX, RTX 4090
- Logitech z5500 5.1
