Rison77
Maglódon körülbelül merre van aktiválva már a 200-as sebesség?
bpx
érdekességképpen
Digi 200
Router Model TP-Link TL-WR1043N/ND v1
Firmware Version OpenWrt Attitude Adjustment 12.09 / LuCI 0.11.1 Release (0.11.1)
Kernel Version 3.3.8(1.8-as egyébként)
Speedtest (197/54 Mbps): [link]
közben a router:
root@OpenWrt:~# top -b -n 100 -d 1 | grep ^CPU
CPU: 0% usr 0% sys 0% nic 98% idle 0% io 0% irq 0% sirq
CPU: 0% usr 0% sys 0% nic 99% idle 0% io 0% irq 0% sirq
letöltés indul:
CPU: 32% usr 13% sys 0% nic 52% idle 0% io 0% irq 0% sirq
CPU: 0% usr 0% sys 0% nic 22% idle 0% io 0% irq 76% sirq
CPU: 0% usr 0% sys 0% nic 0% idle 0% io 0% irq 98% sirq
CPU: 1% usr 0% sys 0% nic 0% idle 0% io 0% irq 97% sirq
CPU: 3% usr 1% sys 0% nic 0% idle 0% io 0% irq 95% sirq
CPU: 3% usr 0% sys 0% nic 0% idle 0% io 0% irq 96% sirq
CPU: 3% usr 0% sys 0% nic 0% idle 0% io 0% irq 95% sirq
CPU: 2% usr 0% sys 0% nic 0% idle 0% io 0% irq 96% sirq
CPU: 21% usr 10% sys 0% nic 63% idle 0% io 0% irq 4% sirq
CPU: 10% usr 1% sys 0% nic 85% idle 0% io 0% irq 1% sirq
CPU: 24% usr 6% sys 0% nic 67% idle 0% io 0% irq 0% sirq
CPU: 0% usr 0% sys 0% nic 97% idle 0% io 0% irq 0% sirq
feltöltés indul:
CPU: 0% usr 1% sys 0% nic 56% idle 0% io 0% irq 41% sirq
CPU: 0% usr 3% sys 0% nic 50% idle 0% io 0% irq 44% sirq
CPU: 10% usr 3% sys 0% nic 37% idle 0% io 0% irq 48% sirq
CPU: 30% usr 13% sys 0% nic 0% idle 0% io 0% irq 55% sirq
CPU: 0% usr 0% sys 0% nic 45% idle 0% io 0% irq 54% sirq
CPU: 0% usr 0% sys 0% nic 51% idle 0% io 0% irq 47% sirq
CPU: 0% usr 0% sys 0% nic 49% idle 0% io 0% irq 49% sirq
CPU: 25% usr 3% sys 0% nic 18% idle 0% io 0% irq 51% sirq
CPU: 16% usr 9% sys 0% nic 9% idle 0% io 0% irq 64% sirq
CPU: 1% usr 0% sys 0% nic 45% idle 0% io 0% irq 51% sirq
CPU: 0% usr 2% sys 0% nic 40% idle 0% io 0% irq 57% sirq
CPU: 1% usr 1% sys 0% nic 47% idle 0% io 0% irq 48% sirq
CPU: 33% usr 7% sys 0% nic 5% idle 0% io 0% irq 53% sirq
CPU: 10% usr 11% sys 0% nic 25% idle 0% io 0% irq 53% sirq
CPU: 0% usr 0% sys 0% nic 55% idle 0% io 0% irq 43% sirqftp:
Copied (2014.07.11 20:49:03): ftp://ftp.fsn.hu/testfiles/1GiB -> z:\1GiB 1 073 741 824 bytes, 22 755 kbytes/s
Copied (2014.07.11 20:51:07): ftp://ftp.fsn.hu/testfiles/1GiB-1 -> z:\1GiB-1 1 073 741 823 bytes, 22 717 kbytes/sAmi ebből nem látszik, hogy mindkét fájlnál egy ponton megállt a letöltés 1-2 mp-re
torrent letöltés 18 MB/s-ig ment fel (3 darab torrent, mindegyiknél egyenként 15000+ seeder, uTorrent default beállítások)
feltöltést ennyi idő alatt nem tudtam kipróbálni[ Szerkesztve ]
#56474624
woodworm
válasz TeeJay #18494 üzenetére
Most mindenki a router miatt aggódik és azon megy a vita, hogy a 800 vagy 900 Mbitet natolni tudó router a jobb, miközben a upc csomagok gyorsítása után tele voltak a topikok az utorrentes "lemez túlterhelt" kérdésekkel.
(#18503) -Zeratul-
A 95-98%-os sirq értékeknél load mit mutatott? -
wwenigma
válasz woodworm #18511 üzenetére
Mert be kell klikkelni az előre lefoglalást. Nem lesz itt baj, csak lassam mar 50-100Mbyte-tal tölteni. Vezek ramot aztan ramdrive-ot nem akasztja ki.
-Zeratul-: érdemes lenne valami frissebb rendszerrel kipróbálni (a trunk Barrier Breaker joval gyorsabb mint amit hasznalsz), illetve a gyárival.
Fr3eWar
Kíváncsi leszek Kecskeméten mikor állnak át.
Most még nálam is csak 90/25-el jön (ennyi szokott lenni, közel vagyok a digi központhoz). -
bpx
(#18509) Dictator^: igen
(#18510) jozsef8: ftp.fsn.hu, felhasználó/jelszó nem kell, anonymous logint válaszd, e-mailt fog kérni, de bármit beírhatsz
(#18511) woodworm: a speedtest-es teszt sajnos túl rövid, de az indítás pillanatában:Load average: 0.01 0.03 0.16
Load average: 0.49 0.13 0.19
ennél magasabb nem is voltEgy hosszabb teszt során folyamatosan "dugul", pl. 3-4 perc után már:
Load average: 3.34 1.50 0.69és ilyen, amikor megáll a letöltés 1-2 mp-re:
Load average: 2.07 0.66 0.36 3/44 1010
CPU: 4% usr 0% sys 0% nic 0% idle 0% io 0% irq 95% sirq
Load average: 2.22 0.72 0.38 4/44 1040
CPU: 8% usr 1% sys 0% nic 0% idle 0% io 0% irq 88% sirq
Load average: 2.22 0.72 0.38 3/44 1041
CPU: 22% usr 12% sys 0% nic 64% idle 0% io 0% irq 0% sirq
Load average: 2.22 0.72 0.38 1/43 1100
CPU: 0% usr 0% sys 0% nic 69% idle 0% io 0% irq 29% sirq
Load average: 2.12 0.72 0.38 2/43 1100
CPU: 0% usr 2% sys 0% nic 0% idle 0% io 0% irq 97% sirq(#18512) wwenigma: gyárival mért pl. Dictator^, azt inkább kihagynám az OpenVPN + dnsmasq hiánya és a (nálam) 2-3 naponta szükséges router újraindítás miatt
a BB-t még lehet kipróbálom -
TeeJay
jaj tudom 80/25-ös időkben is ment a sírás hogy a digiseknek utorrent 1.7 meg minden ősrégi kliens kell mert 3.x verziókkal nem tudnak se letölteni se fel.
hát nekem a legfrissebb van de úgy megy mint a huzat, sosem volt még "lemez túlterhelt" vagy akadás
a lényeg hogy jól legyen beállítva
3.4.2 speciel tökéletes, ott már át is írták az egész I/O részt tehát megszűnt a cache hiba meg minden
úgyhogy fura de 100/50-nél megy mint az atom pedig csak egy alap laptopom van 2,5" vinyóval semmi erőgépMixgyűjteményem ---> https://www.mixcloud.com/teejayhouse/
Ahab77
Más is tapasztalt olyat Szegeden este 9 után (az elmúlt napokban), hogy a net olyan mint Pom-Pom, magyarul 10-20 perces intervallumokkal de teljesen megszakad? Ez ugye nem a routerem hibája? Nyilván nem lehet az mert akkor napközben miért nem látom.
Kép[ Szerkesztve ]
zsolt501
válasz Ahab77 #18519 üzenetére
Bizony igen, én is naponta többször, és este is, de nem csak az internet, hanem a Digi telefonját is érinti a gond.
Én bejelentettem az ügyfélszolgálaton, és holnap kijönnek, de szerintem ez valami központi hiba.''Mind Így van ezzel aki hasonló időket megélt, de a döntés nem rajta állt neked csak arról kell döntened mihez kezdj az idővel amely megadatik.''
ACE-
válasz zsolt501 #18520 üzenetére
Nálam dettó ugyanez, úgy vettem észre, hogy csak erős letöltés közben szakadozik, ha nincs forgalom akkor nem. A telefonra nem tudok nyilatkozni, mert azt nem nagyon használom.
Jul 11 22:32:40 PPP INFO rcvd [LCP TermReq]
Jul 11 22:32:40 PPP INFO send_phase 2098 pppd_phase = 0x7
Jul 11 22:32:40 PPP INFO In pppd the httpd-id is 684, set link phase is 0x7
Jul 11 22:32:40 PPP ERROR LCP down
Jul 11 22:32:40 PPP WARNING LCP down
Jul 11 22:32:40 PPP INFO send_phase 2098 pppd_phase = 0x4
Jul 11 22:32:40 PPP INFO In pppd the httpd-id is 684, set link phase is 0x4
Jul 11 22:32:40 PPP INFO sent [LCP TermAck]
Jul 11 22:32:43 PPP INFO send_phase 2098 pppd_phase = 0xa
Jul 11 22:32:43 PPP INFO In pppd the httpd-id is 684, set link phase is 0xa
Jul 11 22:32:43 PPP INFO send_phase 2098 pppd_phase = 0x0
Jul 11 22:32:43 PPP INFO In pppd the httpd-id is 684, set link phase is 0x0Ilyenek vannak 10-20 percenként.
Revolut (7000 Ft azonnali) Curve (5font)
dokee78
Ez az optikai diginet mennyire stabil?
Upc 120/10-esről váltanék 100/50-es optikai digire. -
TeeJay
válasz dokee78 #18525 üzenetére
elvileg a mai világban az FTTH a csúcs lakossági net technológia
akinek már ott az optikai szál az tegye össze a kezét és adjon hálát mert nagyon mázlista
szerintem azon már most kapásból tudnák adni a gigabitet, kérdés hogy kell-e még valami fejlesztés a hálózat többi részén.Mixgyűjteményem ---> https://www.mixcloud.com/teejayhouse/
VillMernok
Mint az atom, annyira stabil. Ami a névleges sávszél, az van. Amióta a 200/50 megy, azóta az beton annyi. Amíg a 80/25 volt az néha lement 75/22-ra, ez volt a tapasztalt legkisebb sávszél. Itt most nem a tesztoldalakra gondolok, hanem több10GB töltögetésére akármelyik irányban.
Racer77
V1 openwrtvel:
kene84
válasz WarLock07222 #18529 üzenetére
Szia! Már 1 héttel ezelőtt, de nálam azért csak mert 40/20-as netem volt és 100/50 lett a vége.
Neked topnet-ed van és a Te esetedben 200/50 lesz azt hiszem a sebesség, de ezt csak idővel lépi meg a szolgáltató, mert ehhez még a technikai feltételekt biztosítani kell(gigás switch ill. megfelelő kábelezés).
Legalábbis én ezt szűrtem le az elmúlt napok itteni hozzászólásai alapján. -
Sultan
Volt egy kis időm és kiprobáltam router nélkül is a sebességemet.
80/25-ös csomagom van. (volt) Routerral kb. 50/14-et mérek (wifin). Router nélkül pedig 100/25-öt.
A routerem egy Linksys EA2700 ami gigabites.Kérdésem hogy milyen router kellene hogy hozza a 100/25-öt Wifin?
Ez jó lenne?
Vagy ez?
Apple fan! :-)
Zsolteecah
Itt még mindig ugyanazokat az eredményeket mérem
speedtest alá mér mint egy ftp-s teszt megint csak -
Fr3eWar
válasz Sultan #18532 üzenetére
Ez első szerintem gyorsabb.
Nekem volt EA6700-esem és az Wifi-n keresztül hozta a gigabitet. 700-1200 Mbit-volt, tény hogy viszonylag közel voltak az eszközök.
De ehhez olyan cucc kell ami vesz is a delejt. AC szabványú gép.
Én Retina MacBook PRO-val használtam (late 2013-mal) mivel abban nem volt LAN csati, átalakító meg elég drága volt, így vettem egy EA6700-es routert.2011-es macbookból sosem fogsz 100megabitet kicsalni wifin.
Ott az 50-70megabit (valós) a plafon (N-es 300megabites konfignál)[ Szerkesztve ]
zsolt501
Csúnyán indul a mai nap, ma mióta felkeltem már 2x elment a net, az este folyamán is volt több megszakadás, ez így nagyon nem jó...
Szegeden a Csillag tér környékén tapasztal még valaki hasonlót?''Mind Így van ezzel aki hasonló időket megélt, de a döntés nem rajta állt neked csak arról kell döntened mihez kezdj az idővel amely megadatik.''
frankee200
Topnet 8/25 emelték Topnet 200-ra de nem tudok 103 Mbit-nél többet mert a modem ZTE ZXA10 F625a modemben a ZTE szerint csak 10/100 Base kapcsoló van. Szerintetek ha ugrálok kicserélik a modemet?
Drenadar
100/50es net
HZoli87
válasz frankee200 #18542 üzenetére
Én biztos szólnék érte, ha valóban 100-as akkor szerintem cserélniük kell.
sethyx
válasz Zsolteecah #18537 üzenetére
~200 országból a 13 szerintem top.
De csak azért, mert ez Átlag. Sosem cáfoltam, hogy az ország egy jó részében nagyon szerények a lehetőségek, pl. szüleimnél ahova néha vidékre látogatok 10/0,5Mbps a max... Nekem meg remélhetőleg hamarosan kötik az 1000/100-at. Enyhe kontraszt.
A digi egy remek szolgáltató, de sajnos nagyon kevés helyen van jelen, ezzel az emeléssel az átlagot pedig ismét iszonyat meg fogja ugrasztani... -
zibo73
válasz Zsolteecah #18547 üzenetére
Helló!
Ezzel nekem is szarul mér, de a datanet meg jó.próbáld meg másikkal mérni.
Bocsi ez Drenadar ment volna![ Szerkesztve ]
Olvasd el az összefoglalót!
Társtopikok:
● DIGI kábel TV
● DIGI Mobil
● DIGI műholdas TV
● DIGI vezetékes telefon
● Milyen routert?
● Router gondok
- Ukrajnai háború
- Ennyibe kerülnek a Huawei Pura modellek Európában
- Sokat fogyaszt az AI, egyre több az adatközpont, kell az atomenergia
- Robogó, kismotor
- Milyen cserélhető objektíves gépet?
- EDIFIER R1700BTS hangfal pár makulátlan, új állapotban, 2 év hivatalos garanciával, alkalmi áron
- LG OLED55B23LA 2 Év GYÁRI GARANCIA
- Apple iPhone XR 128GB, Kártyafüggetlen, 1 Év Garanciával
- Gamer PC , i7 12700KF , RTX 3080 Ti , 64GB DDR5 , 960GB NVME , 1TB HDD
- Intel PC , i5 8500 , 1660 6GB , 32GB DDR4 , 512GB NVME , 500GB HDD
