- HyperX Fury DDR4 - 3200 - CL16 - 16GB RAM (8GB x 2) RGB
- LG 34WQ500-B - 34" IPS LED - 2560x1080 Wide FHD - 100Hz 5ms - AMD FreeSync - HDR10
- LG 27UL550-W - 27" IPS / 3840x2160 4K / 60Hz 5ms / HDR10 / AMD FreeSync
- Samsung Galaxy S22 8/128 GB Phantom White ÚJ, gariban cserélt! 6 Hónap Jótállás
- AKCIÓ! ASUS ROG G16 (2025) G615LR 16 - Ultra 9 275HX 32GB DDR5 1TB SSD RTX 5070Ti 12GB WIN11
