- G.SKILL Trident Z Neo RGB 32GB (2x16GB) DDR5 6000MHz F5-6000J3238F16GX2-TZ5NR
- Bomba ár! Lenovo V15-ADA - Ryzen 3 I 8GB I 256SSD I 15,6" FHD I Radeon I HDMI I Cam I W11 I Gari
- HIBÁTLAN iPhone 14 128GB Red -1 ÉV GARANCIA - Kártyafüggetlen, MS3159, 100% Akksi
- iPhone 13 Pro 128GB Gold -1 ÉV GARANCIA - Kártyafüggetlen, MS3963, 100% Akkumulátor
- Asus laptop E1504F Ryzen 3
- Shining3D EinScan Pro 2X 3D szkenner
