- Trident Z5 RGB DDR5-7200 CL34-45-45-115 1.40V 32GB (2x16GB)
- Bomba ár! HP 250 G9 - i5-1235U I 8GB I 128GB SSD I HDMI I 15,6" FHD I HDMI I W11 I Cam I Garancia!
- Bomba ár! Lenovo X1 Carbon 4th: i5-6GEN I 8GB I 512SSD I 14" FHD I HDMI I Cam I W11 I Gari
- Bomba ár! HP ProBook 450 G3 - i5-6G I 8GB I 128SSD I DVDRW I HDMI I 15,6" HD I Cam I W11 I Gar!
- Razer gamer szék
