- G.SKILL Trident Z Neo RGB 32GB (2x16GB) DDR5 6000MHz F5-6000J3238F16GX2-TZ5NR
- HyperX Fury DDR4 - 3200 - CL16 - 16GB RAM (8GB x 2) RGB
- AKCIÓ! Lenovo Legion Slim 5 Gamer notebook - R7 7435HS 16GB RAM 1TB SSD RTX 4070 8GB GDDR6 WIN11
- Apple iPhone 12 Mini / 256GB / Kártyafüggetlen / 12Hó Garancia / Akku: 89%
- Bomba ár! HP EliteBook 2760P - i5-G2 I 4GB I 320GB I 12,1" Touch I Cam I W10 I Garancia!
- BESZÁMÍTÁS! ASUS H510M i7 10700 16GB DDR4 512GB SSD RTX 3060 Ti OC 8GB Zalman Z1 PLUS ADATA 600W
- OnePlus Nord 2T 128GB, Kártyafüggetlen, 1 Év Garanciával
