HookR
Azt hiszem, itt a megoldás. Idézet a korabeli Anandtech cikkből:
"As for the cards themselves, AMD will be releasing two Cape Verde cards: the Radeon HD 7750, and the Radeon HD 7770 GHz Edition. The 7770 will be a fully enabled Cape Verde with all 10 CUs (640 SPs) enabled, running at 1GHz for the core clock and 4.5GHz for the memory clock, with a PowerTune limit of 100W and an AMD defined typical board power of 80W. The 7750 meanwhile has 2 disabled CUs, giving it 512 SPs and 32 texture units, while the ROP count is unchanged at 16. The core clock will be 800MHz while the memory clock is the same as the 7770 at 4.5GHz, with a PowerTune limit of 75W and a typical board power of 55W. Both cards have a sub-10W idle TDP, while long-idle is sub-3W."
- Gyúrósok ide!
- Vivo X300 Ultra - tárcsázz, ha van rá keret!
- sziku69: Szólánc.
- Mától Huawei okosórákkal is lehet érintésmentesen fizetni
- Fotók, videók mobillal
- Xbox tulajok OFF topicja
- Az AI átformálja a Peugeot modelljeit is
- Kingston FURY Beast 16GB (2x8GB) DDR4 3600MHz
- Kingston FURY Beast 16GB (2x8GB) DDR4 3200MHz
- Kingston FURY Beast RGB 64GB (2x32GB) DDR5 6000MHz KF560C40BBAK2-64
- Asus ROG STRIX Z890-A GAMING WIFI - GARANCIA: 2028.12.16 - FirstShop
- AKCIÓ! ASUS Z790 i9 14900KF 64GB DDR5 1TB SSD RTX 5080 16GB LIAN LI LANCOOL 216R ADATA 850W
- Lenovo Thinkpad E595 Ryzen 5 3500U, Radeon Vega 8, 8-16GB RAM, SSD, jó akku, számla, gar
- LG UltraWide 35WN75CP VA Monitor! 3440x1440 / 100Hz / sRGB 99% / FreeSync
- 27% - Yodoit PTM15 hordozható 15,6 monitor! 1920x1080p / IPS / hangszórókkal
- Egérpadok, billentyűsapkák(keycapek), csuklótámaszok /ARCANE/DUCKY/GLORIOUS/
