- G.SKILL Trident Z5 Royal NEO RGB 32GB (2x16GB) DDR5 6000MHz CL28
- Új, bontatlan G.SKILL 32GB (2x16GB) KIT DDR5 6000MHz CL36 Ripjaws M5 Neo RGB White EXPO - 10 év gari
- Új, bontatlan ADATA XPG 32GB (2x16GB) KIT DDR5 6000MHz CL30 Lancer Blade Black XMP/EXPO - 10 év gari
- Új, bontatlan ADATA XPG 48GB (2x24GB) KIT DDR5 6000MHz CL30 Lancer Blade RGB Black - 10 év garival!
- Patriot Viper RGB Elite 5 Ultra - 48GB (2x24) DDR5 6000MHz CL28 - 10 év garancia
- Bomba ár! HP 250 G7 - i5-8G I 8GB I 256SSD I NVIDIA I HDMI I 15,6" FHD I HDMI I W11 I Cam I Gari!
- BESZÁMÍTÁS! ASUS H510M i3 10105F 16GB DDR4 240GB SSD 1TB HDD GTX 1050Ti 4GB Zalman T4 ADATA 600W
- HP EliteBook 840 G7 i5-10210U 16GB 512GB FHD 400nit 1 év garancia
