- G.SKILL Trident Z5 Royal NEO RGB 32GB (2x16GB) DDR5 6000MHz CL28
- Új, bontatlan G.SKILL 32GB (2x16GB) KIT DDR5 6000MHz CL36 Ripjaws M5 Neo RGB White EXPO - 10 év gari
- Új, bontatlan ADATA XPG 32GB (2x16GB) KIT DDR5 6000MHz CL30 Lancer Blade Black XMP/EXPO - 10 év gari
- Új, bontatlan ADATA XPG 48GB (2x24GB) KIT DDR5 6000MHz CL30 Lancer Blade RGB Black XMP/EXPO - 10 év
- Patriot Viper RGB Elite 5 Ultra - 48GB (2x24) DDR5 6000MHz CL28 - 10 év garancia
- HIBÁTLAN iPhone 12 Mini 64GB Green -1 ÉV GARANCIA - Kártyafüggetlen, MS3453, 100% Akkumulátor
- BESZÁMÍTÁS! Asus H370-A i5 9600K 16GB DDR4 512GB SSD RTX 2060 Super 8GB Zalman T7 Zalman 500W
- HP ZBook Firefly 14 i7-1165G7 16GB 1000GB Nvidia Quadro T500 4GB 14" FHD 1 év garancia
- Bomba ár! HP ProBook 450 G3 - i7-6G I 8GB I 256SSD I DVDRW I HDMI I 15,6" FHD I Cam I W11 I Gar!
