- Új, bontatlan ADATA XPG 32GB (2x16GB) KIT DDR5 6000MHz CL30 Lancer Blade Black XMP/EXPO - 10 év gari
- Patriot Viper Elite 5 Ultra - 48GB (2x24) DDR5 6400MHz CL32 - 10 év garancia
- 16GB (30k) / 32GB (50k) DDR5 laptop ram csak 1-1db
- Apple iPhone 16 - Black - 128GB - Akku: 100% - ÚJ - BONTATLAN - 1 ÉV APPLE JÓTÁLLÁS - FÜGGETLEN
- 5G LTE! Microsoft Surface Pro 8 i7-1185G7 16GB 1000GB 1 év garancia
- Honor Magic 7 Pro 512 Gb - AI Pro kamera, 6,8 120 Hz LTPO OLED, Snapdragon 8 Elite,3 hó gari!
- Bomba ár! HP EliteBook 840 G6 - i7-8GEN I 16GB I 512GB SSD I 14" FHD I HDMI I Cam I W11 I Gari!
- REFURBISHED és ÚJ - DELL Thunderbolt Dock WD22TB4 (210-BDTD)
