- HyperX Fury DDR4 - 3200 - CL16 - 16GB RAM (8GB x 2) RGB
- GIGABYTE B760 GAMING X AX WIFI - Garancia 2027.09.06.
- Bomba ár! HP Probook 450 G10 - i3-1315U I 16GB I 256SSD I 15,6" FHD I W11 I Cam I Garancia!
- LENOVO Legion Pro 5 16IRX8 - 16" WQXGA 240Hz - i5-13500HX - 16GB - 1TB - RTX 4060 - 9 Hó garancia
- magyar billentyűzet - 136 - Lenovo Legion Pro 7 (16IRX9H) - i9-14900HX, RTX 4080 - 4 ÉV GARANCIA!
- Bomba ár! HP ProBook 640 G4 - i5-8GEN I 8GB I 256GB SSD I 14" FHD I Cam I W11 I Garancia!
- HIBÁTLAN iPhone 13 128GB Pink -1 ÉV GARANCIA - Kártyafüggetlen, MS3925, 100% Akkumulátor
