- 8x16 ddr4 vízhűtéses ram
- GIGABYTE B760 GAMING X AX WIFI - Garancia 2027.09.06.
- HyperX Fury DDR4 - 3200 - CL16 - 16GB RAM (8GB x 2) RGB
- BESZÁMÍTÁS! ASRock B450M R5 Pro 3400G 16GB DDR4 240GB SSD 2TB HDD GTX 1070 8GB RAMPAGE Shiva 450W
- GYÖNYÖRŰ iPhone 11 Pro Max 64GB Midnight Green -1 ÉV GARANCIA - Kártyafüggetlen, MS3253, 100% Akksi
- LG 49WQ95X-W - 49" NANO IPS - 5120x1440 Dual QHD - 144Hz - USB Type-C - HDR 400 - G-Sync - FreeSync
- REFURBISHED - DELL Universal Dock D6000 (452-BCYH) (DisplayLink)
- LG 34GN850P-B - 34" Ívelt Nano IPS - 3440x1440 - 160Hz 1ms - G-Sync - FreeSync - HDR 400
