- G.SKILL Trident Z5 Royal NEO RGB 32GB (2x16GB) DDR5 6000MHz CL28
- Új, bontatlan G.SKILL 32GB (2x16GB) KIT DDR5 6000MHz CL36 Ripjaws M5 Neo RGB White EXPO - 10 év gari
- Új, bontatlan ADATA XPG 32GB (2x16GB) KIT DDR5 6000MHz CL30 Lancer Blade Black XMP/EXPO - 10 év gari
- Új, bontatlan ADATA XPG 48GB (2x24GB) KIT DDR5 6000MHz CL30 Lancer Blade RGB Black XMP/EXPO - 10 év
- Patriot Viper RGB Elite 5 Ultra - 48GB (2x24) DDR5 6000MHz CL28 - 10 év garancia
