- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- BESZÁMÍTÁS! ASUS B560 i7 11700 32GB DDR4 512GB SSD RTX 4060Ti 16GB RAMPAGE Shiva A-Data 650W
- LG 25GR75FG - E-Sport Monitor - FHD 360Hz 1ms - NVIDIA Reflex + G-sync - AMD FreeSync - HDR 400
- GYÖNYÖRŰ iPhone 12 Pro Max 128GB Pacific Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS3940, 100% Akku
- Samsung Galaxy Tab S6 Lite 64GB,Átlagos,Dobozával,12 hónap garanciával
- Sound Blaster AE-7 (B-Stock)
