- ROG STRIX B660-F GAMING WIFI
- Bomba ár! Toshiba Satellite Pro A40-D - i5-7200U I 8GB I 256SSD I 14" HD I Cam I W11 I Garancia!
- Bomba ár! Dell Latitude E5550 - i5-5GEN I 8GB I 128SSD I 15,6" FHD Touch I HDMI I W10 I Cam I Gari!
- LG 27GR95QL - 27" OLED / Limitált LoL Edition / QHD 2K / 240Hz & 0.03ms / NVIDIA G-Sync / FreeSync
- Samsung Galaxy Ring 12mm, 1 Év Garanciával
