Archttila
"Today I start my work on an window kit for the A4-SFX. Do you like it? Currently I work on a version without visible screws" (dondan)
"It is a black tempered glass version with 5mm standoffs between side panel and glass. I think the temps will be a bit higher as with the default panel. But the great thing is, that I can made thins panel for both sides."
- Gamer PC-Számítógép! Csere-Beszámítás! I5 9600KF / RTX 3060Ti / 16GB DDR4 / 256SSD + 2TB HDD
- DELL LATITUDE 5420 üzleti laptop garanciával 14", i5-11345G7 16gb ram 256ssd FHD
- Garmin Forerunner 405 GPS óra
- 5G Lenovo ThinkPad P14s Gen 3 Intel Core i7-1280P Nvidia T550 32GB 1000GB 1 év teljeskörű garancia
- WYBOT C2 Vision AI vezérelt medenceporszívó
