- G.SKILL Trident Z5 RGB 32GB (2x16GB) DDR5 7200MHz
- Bomba ár! Lenovo IdeaPad V330: i5-8250U I 8GB I 256SSD I 15,6" FHD I Cam I W11 I Garancia!
- Honor 200 Lite / 8/256GB / Kártyafüggetlen / 12HÓ Garancia
- Új MSI GF63 Thin 15 FHD IPS 144Hz i7-12650H 10mag 16GB 512GB SSD Nvidia RTX 4060 8GB Win11 Garancia
- 164 - Lenovo Legion Pro 7 (16IRX9H) - Intel Core i9-14900HX, RTX 4090
