- OLED TV topic
- Battlefield 6
- Háztartási gépek
- E-roller topik
- LG 27GR95UM - 27" MiniLED - UHD 4K - 160Hz 1ms - NVIDIA G-Sync - FreeSync Premium PRO - HDR 1000
- BESZÁMÍTÁS! GIGABYTE B650M R5 7600 32GB DDR5 1TB SSD RX 9070 16GB NZXT H700 Cooler Master 750W
- SanDisk Extreme Portable 8TB (SDSSDE61-8T00-G25)
- Epson Workforce DS-530II dokumentumszkenner
- LG 55C4 - 48" OLED evo - 4K 144Hz - 0.1ms - NVIDIA G-Sync - FreeSync - HDMI 2.1 - A9 Gen7 CPU
