- G.SKILL Trident Z RGB 16GB (2x8GB) 3000MHz DDR4 kit/ BESZÁMÍTÁS OK!
- BONTATLAN Corsair Vengeance 32GB KIT (2x16GB) DDR5 7000MHz CL34 Black - 99 hó gari
- BONTATLAN Corsair Vengeance 32GB KIT (2x16GB) DDR4 3600MHz CL18 RGB PRO SL - 5 év gari
- ASUS ROG STRIX X870-A Gaming WIFI alaplap Bontatlan
- BONTATLAN Corsair Vengeance 32GB KIT (2x16GB) DDR5 7200MHz CL34 - 99 hó gari
- Beszámítás! Acer Nitro V16 ANV16 120Hz Gamer notebook - R7 8845HS 32GB DDR5 1TB SSD RTX 4060 8GB W11
- 201 - Lenovo Yoga Slim 7 (15ILL9) - Intel Core U7 258V, no GPU (ELKELT)
- NEC MultiSync V421 42" Monitor
- LG 32GR93U-B - 32" IPS - UHD 4K - 144Hz 1ms - NVIDIA G-Sync - FreeSync Premium - HDR 400
- HIBÁTLAN iPhone XR 64GB Red-1 ÉV GARANCIA - Kártyafüggetlen, MS4490,100% Akksi
