Archttila
patomi
#39769
Azóta mar vannak új hírek
(tegnapi)Intel is beginning to feel the pinch of AMD Ryzen 7-series, and the upper-end of the Ryzen 5-series, which offer better multi-threaded performance than similarly-priced quad-core Intel Core i7 and Core i5 "Kaby Lake" processors, and reasonably good single-thread performance, and platform costs. The company is responding in force with four new six-core SKUs, and for the first time since "Nehalem," the company isn't changing the socket with the introduction of its third mainstream-desktop micro-architecture on a given process. The 8th generation Core "Coffee Lake" mainstream-desktop processors will be built in the existing LGA1151 package, and will hopefully support existing motherboards through BIOS updates, even though Intel plans a new 300-series chipset to go with these chips.
- Parkside szerszám kibeszélő
- World of Tanks - MMO
- Apple MacBook
- Július 9-én jön az Assassin’s Creed: Black Flag Resynced
- gerner1
- 16GB ( 2x8GB ) DDR4 2666MHz Notebook SODIMM Ram Memória
- Keresünk iPhone 16/16 Plus/16e/16 Pro/16 Pro Max
- GAMING PC! Intel i5-12400F / RTX 4060 Ti / 16GB DDR4 / H610 / 512GB NVMe / 600w! BeszámítOK
- Thermalright Phantom Spirit 120 SE
- Apple iPhone 13 Pro Max / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku:86%
- AKCIÓ! Asus Z170-A Z170 chipset alaplap garanciával hibátlan működéssel
(tegnapi)
