- Új, bontatlan Kingston FURY 32GB (2x16GB) DDR5 6000MHz CL36 Beast XMP/EXPO - 2 év bolti garival! -
- HyperX Fury DDR4 - 3200 - CL16 - 16GB RAM (8GB x 2) RGB
- Bomba ár! HP Pro X360 11 G1 - Intel N4200 I 4GB I 128GB SSD I 11,6" HD Touch I Cam I W11 I Gari
- Bomba ár! HP Elitebook 8570P - i5-3340M I 8GB I 500GB HDD I DisplayPort I 15,6" HD I Garancia!
- BESZÁMÍTÁS! MSI B450M R5 5600X 32GB DDR4 1TB SSD RTX 4070 12GB Rampage SHIVA Cooler Master 750W
- G.SKILL Trident Z RGB 32GB (2x16GB) DDR4 4800MHz
