vastalics
-Integrated Graphics Processor+Intel® Thunderbolt™ 4 Controller: 2 x Intel® Thunderbolt™ 4 connectors (USB Type-C® ports), supporting DisplayPort and Thunderbolt™ video outputs and a maximum resolution of 5120x2880@60 Hz with 24 bpp (via single display output)
* Because of the limited I/O resources of the PC architecture, the number of Thunderbolt™ devices that can be used is dependent on the number of the PCI Express devices being installed. (Refer to Chapter 1-7, "Back Panel Connectors," for more information.)
* Support for DisplayPort 1.4 version and HDCP 2.3.
(Graphics specifications may vary depending on CPU support.)-Chipset+Intel® Thunderbolt™ 4 Controller: 2 x USB Type-C® ports on the back panel, with USB 3.2 Gen 2 support
Ezek szerint igen!
- Frissen pasztázva! Playstation 4 Pro 1 TB + kontroller 6 hó garancia, számlával!
- 171 - Lenovo Legion Pro 7 (16IAX10H) - Intel Core U9 275HX, RTX 5080 (ELKELT)
- HIBÁTLAN iPhone 13 Pro 256GB Sierra Blue-1 ÉV GARANCIA - Kártyafüggetlen, MS4662, 90% AKKSI
- Asus ROG Strix G16 Notebook! i9-14900HX / RTX 4060 / 16GB DDR5 / 1TB NVMe! BeszámítOK
- 27% - HEIGAOLA MiniPC - / 10.1" Érintőképernyő! Intel J4125 / 8GB RAM /128GB SSD
