HookR
Immáron elérhető a Silverstone SG08 is. (SG07 belső, alu előlappal)
"For the first time in a SilverStone product and likely also the first for Mini-ITX, a 1cm (0.4 inch) thick extruded aluminum was used to adorn the front panel of a chassis."
- ASUS ROG STRIX B550-F GAMING Eladó!
- Asus ROG STRIX Z890-A GAMING WIFI - GARANCIA: 2028.12.16 - FirstShop
- Erying ITX 12800H alaplap (Integrált 14 magos i7 CPU, 3x NVMe) Hiánytalan tartozékokkal
- Lenovo T14 Thinkpad G3 WUXGA IPS i5-1245U vPro 10mag 16GB 256GB SSD Intel Iris XE Win11 Pro Garancia
- iPhone 15 Pro Max 256GB 84% (1év Garancia)
- GAMING PC! Ryzen 7600X / RX 7800 XT / 32GB DDR5 / 512GB NVMe / 700w! BeszámítOK
- Lenovo X1 Yoga G4 i5-8265 számlával, garanciával
- GYÖNYÖRŰ iPhone 14 Pro 128GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4322
