eisento
wwenigma
#38910
vki irna egy rovid osszefoglalot ha vmit a routerbe kell allitanom akkor mi is legyen az?
gondolom a wan connection type az pppoev6
ha ezt kivalasztom lesz usernam meg jelszo gondolom ide kell a digis username/password
tobbit nem tudom
WAN Connection Type:
Choosing the correct WAN connection type based on your ISP network topology.
DHCPv6 - Connections which use dynamic IPv6 address assignment.
Static IPv6 - Connections which use static IPv6 address assignment.
PPPoEv6 - Connections which use PPPoEv6 that requires a user name and password.
Tunnel 6to4 - Connections which use 6to4 address assignment.
User Name/Password - Enter the User Name and Password provided by your ISP. These fields are case-sensitive.
Get IPv6 Address Way
Get non-temporary IPv6 address - Get a non-temporary IPv6 address by DHCPv6 from the ISP.
Get IPv6 prefix delegation - Get a prefix delegation IPv6 address by DHCPv6 from the ISP, and the clients in LAN create IPv6 address with the delegation.
Use IP address specified by ISP - Input a static IPv6 address from the ISP.
Click the Connect button to connect immediately.
Click the Disconnect button to disconnect immediately.
Configure the IPv6 parameters of LAN:
IPv6 Address Assign Type - SLAAC(Stateless address autoconfiguration) and DHCPv6(Dynamic Host Configuration Protocol for IPv6) Server.
IPv6 Address Prefix - The Prefix of IPv6 Address.
Release Time - The Release Time is the length of time a network user will be allowed to keep connecting to the Router with the current DHCPv6 Address. Enter the amount of time, in seconds, that the DHCPv6 address will be "leased". The time range is 1~691200 seconds. The default value is 86400 seconds.
LAN IPv6 Address - Display the LAN IPv6 Address.
Olvasd el az összefoglalót!
Társtopikok:
● DIGI kábel TV
● DIGI Mobil
● DIGI műholdas TV
● DIGI vezetékes telefon
● Milyen routert?
● Router gondok
- 250GB Sata SSD-k / Samsung 840 Evo / 850 Evo / CM871a / Kingmax /
- ASUS ROG G70S retro gamer laptop 17 dual GPU SLI ritka különlegesség
- Asus ROG Strix G731GT - 17.3"FHD IPS 120Hz - i7-9750H - 8GB - 512GB SSD - 1TB HDD - GTX 1650 - Win11
- Vízhűtéses gép eladó!
- Kingston HyperX FURY RGB 16GB (2x8GB) DDR4 3200MHz
- iPhone Xr 64GB 100% ÚJ EREDETI AKKUMULÁTOR Gyűjtői darab (3hónap Garancia)
- Apple iPhone 16 Pro Max 256GB Black Titanium használt, szép állapot 96% akku (247 ciklus) 6 hó
- 4TB Gen4x4 SSD
- BESZÁMÍTÁS! 2TB Kingston KC3000 NVMe SSD meghajtó garanciával hibátlan működéssel
- 228 - Lenovo LOQ (15IRX10) - Intel Core i7-13650HX, RTX 5060
