mrbig25
viperabácsi
#13299
- GYÖNYÖRŰ iPhone 13 Pro 256GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS3074, 100% Akkumulátor
- LG 27UN880-B - 27" IPS ERGO - 3840x2160 4K - 60Hz - DisplayHDR 400 - USB Type-C - AMD FreeSync - Mac
- BESZÁMÍTÁS! ASUS H510M i7 10700 16GB DDR4 512GB SSD RTX 3060 12GB GDDR6 Zalman T4 Plus ADATA 600W
- Gamer szék ASUS ROG Destrier Ergo SL400
- LG OLED TV 55CS6LA
