- GIGABYTE B650E AORUS STEALTH ICE
- Kingston FURY 32GB (2X16GB) KIT DDR5 5600MHz CL36 Beast Black XMP/EXPO - 1 év gari! -
- Kingston FURY 64GB (2x32GB) KIT DDR5 6000MHz CL36 Beast Black XMP/EXPO - 1 év bolti garival! -
- Új, bontatlan Corsair 32GB (2x16GB) KIT DDR5 6000MHz CL36 Vengeance White XMP - 10 év bolti gari!
- ASUS ROG STRIX Z490-F GAMING Alaplap
- BESZÁMÍTÁS! MSI B450M R7 5700X 32GB DDR4 500GB SSD RTX 4060 Ti 8GB Zalman Z1 PLUS Cooler Master 700W
- SzuperÁron! 5G LTE! Microsoft Surface Pro 8 i7-1185G7 16GB 512GB 1 év garancia - hajszálrepedt
- GYÖNYÖRŰ iPhone 13 Mini 128GB Midnight - 1 ÉV GARANCIA -Kártyafüggetlen, MS4195, 94% Akksi
- VICC ÁR! Dell Precision 7530 - Xeon E2186M (i9-8950HK++) / 32GB RAM 512GB SSD Quadro P2000
- Cisco Catalyst C1000-48T-4G-L 48xRJ45 4xSFP switch, CISCO refurbished
