- HIBÁTLAN iPhone 13 Mini 256GB Red -1 ÉV GARANCIA - Kártyafüggetlen, MS4428
- Dell Precision 7550,15.6,FHD,i7-10850H,16GB DDR4,256GB SSD,Quadro T2000 4GB VGA,WIN11,LTE
- LG 34WQ75X-B - 34" Ívelt IPS Panel - 3440x1440 2K QHD - 60Hz 5ms - FreeSync - USB Type-C 90W
- Xiaomi Redmi 14C / 4/128GB / Kártyafüggetlen / 12Hó Garancia
- Dell 14 Latitude 5430 FHD IPS i7-1255U vPro 4.7Ghz 10mag 16GB 256GB Intel Iris XE Win11 LTE Garancia
