- G.SKILL Ripjaws V 2x4GB 3000MHz DDR4 kit
- Corsair VENGEANCE 32GB (2x16GB) DDR5 6000MHz CL36 - XMP/EXPO - 120 hó garancia
- Kingstone Fury DDR5 16GB 6000Mhz 2x8GB
- ADATA XPG Lancer Blade 32GB (2x16GB) DDR5 6000MHz CL34 - XMP/EXPO - 120 hó garancia
- CSÍKOS! MacBook Pro 16" M1 Pro 16GB 512GB Gar.
- BESZÁMÍTÁS! MSI B760 i7 13700K 32GB DDR4 2TB SSD RTX 4080 16GB be quiet! 500DX Seasonic 750W
- Bomba ár! HP ProBook 640 G8 - i5-1145G7 I 16GB I 512GB SSD I 14" FULLHD I Cam I W11 I Gari!
- BESZÁMÍTÁS! Asus H370 i7 8700 16GB DDR4 512GB SSD RX 5600 XT 6GB Zalman S2 TG Cooler Master 650W
- Dell Latitude 7210 2-in-1 12" FHD touch, i7 10610U, 16GB RAM, 512GB SSD, jó akku, számla, 6 hó gar
