HookR
Esedékessé vált a 4-nél több meghajtót kezelő mini-ITX alaplapok listájának aktualizálása - a teljesség igénye nélkül. (Pl. nem tartalmazza az integrált CPU/APU-s alaplapokat sem.)
12 SATA:
- ASRock C2550D4I
- ASRock C2750D4I7 SATA + 1 eSATA:
- ASRock FM2A85X-ITX6 SATA + 1 eSATA:
- ASRock FM2A88X-ITX+
- ASRock H87E-ITX/ac
- ASRock Z87E-ITX
- ASRock X99E-ITX/ac (SATA Express 10Gb/s / Ultra M.2 PCIe 3.0 x4 32Gb/s - 42/60/80 mm)
- Zotac H55-ITX-C-E WiFi
- Zotac H67-ITX WiFi6 SATA:
- ASRock FM2A78M-ITX+
- ASRock Z97E-ITX/ac (SATA Express 10Gb/s / M.2 PCIe 2.0 x2 10Gb/s - 30/42 mm)
- ASRock Fatal1ty Z170 Gaming-ITX.ac (SATA Express 10Gb/s / M.2 PCIe 3.0 x4 32Gb/s - 60/80 mm)
- Asus H87I-Plus
- Asus P8H67-I
- Asus P8H77-I
- Asus Z87I-Pro
- Commel LV-678
- Gigabyte GA-2AIEV-RH
- Gigabyte GA-H97N-WiFi
- Gigabyte GA-Z97N-WiFi
- Gigabyte GA-H170N-WiFi (SATA Express 16Gb/s / M.2 PCIe 3.0 x4 32Gb/s - 60/80 mm)
- Gigabyte GA-Z170N-WiFi (SATA Express 16Gb/s / M.2 PCIe 3.0 x4 32Gb/s - 60/80 mm)
- Gigabyte GA-Z170N-Gaming 5 (SATA Express 16Gb/s / M.2 PCIe 3.0 x4 32Gb/s - 60/80 mm)
- Jetway NF9A Q67
- Jetway NF9E Q77
- Jetway NF82
- Kontron KTQM67
- Kontron KTQM77
- Portwell WADE-86565 SATA + 2 PATA:
- ASL R780G HTPC5 SATA + 1 eSATA:
- Jetway NC97R-LF
- Gigabyte GA-Z97N-Gaming 5
- MSI B85I Gaming
- MSI Z87I Gaming AC
- Zotac G43ITX-A-E
- Zotac H77-ITX WiFi (mSATA)5 SATA:
- ASRock H97M-ITX/ac
- ASRock Z97M-ITX.ac
- ASRock B150M-ITX/D3 (mSATA)
- ECS H97I-Drone
- ECS Z97I-Drone4 SATA + 2 PATA + 1 eSATA:
- Albatron KI780G
- J&W MINIX 780G-SP128MB
- J&W MINIX 785G-SP128M4 SATA + 2 PATA:
- Jetway NC62K-LF
- Sapphire IPC-AM3DD785G4 SATA + 2 eSATA:
- Asus P8Z77-I Deluxe
- EVGA Z77 Stinger
- Jetway NC81-LF
- Jetway NC84
- MSI Z97I Gaming AC4 SATA + 1 eSATA:
- ASRock A75M-ITX
- ASRock B75M-ITX
- ASRock B85M-ITX
- ASRock H87M-ITX
- ASRock FM2A75M-ITX
- ASRock H67M-ITX
- ASRock H77M-ITX
- ASRock Z68M-ITX
- ASRock Z77E-ITX
- Asus F1A75-I Deluxe
- Asus Maximus VI Impact (M.2 PCIe 2.0 x1 5Gb/s - 42/60/80/110 mm)
- ECS H55H-I
- ECS H67H2-I
- EVGA Z87 Stinger
- EVGA Z97 Stinger
- Giada MI-H55
- Giada MI-R880G
- Gigabyte GA-A75N-USB3
- Gigabyte GA-H55N-USB3
- Gigabyte GA-H67N-USB3(-B3)
- Gigabyte GA-Q87N
- Intel DG45FC
- Intel DH57JG
- Intel DH67CF
- Intel DH77DF
- Intel DQ45EK
- Intel Mini-ITX H57
- J&W MINIX H55-HD
- MSI A85IA-E53
- MSI Z77IA-E53
- Zotac 890GX-ITX WiFi4 SATA:
- Asus Maximus VII Impact (M.2 PCIe 3.0 x4 32Gb/s - 42/60/80/110 mm)
- Asus H97I-Plus (M.2 PCIe 3.0 x2 10Gb/s)
- Asus Z97I-Plus (M.2 PCIe 3.0 x2 10Gb/s)
- Asus H170I-Plus D3 (SATA Express / M.2 PCIe 3.0 x4 32Gb/s - 42/60/80 mm)
- Asus Z170i Pro Gaming (SATA Express / M.2 PCIe 3.0 x4 32Gb/s - 42/60/80 mm)
- Gigabyte GA-B85N (mSATA)
- Gigabyte GA-B85N Phoenix (mSATA)
- Gigabyte GA-B85N WiFi (mSATA)
- MSI Z97I Gaming ACK (M.2 PCIe 3.0 10Gb/s)
- MSI Z170I Gaming Pro AC (SATA Express / M.2 PCIe 3.0 x4 32Gb/s - 42/60 mm)
- Sapphire Pure Platinum Z77i (mSATA)
- Zotac Z77-ITX WiFi (mSATA)
- Zotac H87-ITX WiFi (mSATA)- Előfordulhat, hogy egyes alaplapok esetében az eSATA valamelyik SATA csatlakozóval osztozik. Érdemes utánaolvasni a kiszemelt darabnak!
- Sikítsatok, ha vala kimaradt, aminek itt a helye!
- Peugeot, Citroën topik
- LEGO klub
- E-roller topik
- Horgász topik
- Battlefield 6
- Milyen széket vegyek?
- Kingston HyperX és FURY 16Gb (20-22k) és 32GB DDR4 (47k) laptop ramok párban is 2666Mhz/3200Mhz
- GYÖNYÖRŰ iPhone 12 mini 256GB Red -1 ÉV GARANCIA -Kártyafüggetlen, MS3627
- Dell Precision 5570! 4K Touch / i7-12800H / RTX A2000 / 32GB DDR5 / 512GB NVMe! BeszámítOK
- HIBÁTLAN iPhone 15 Pro 256GB White Titanium-1 ÉV GARANCIA - Kártyafüggetlen, MS4448
- iPhone 16 Pro 512GB 96% (1év Garancia) ! Utángyártott, jó minőségű kijelző !
- GYÖNYÖRŰ iPhone 14 128GB Midnight -1 ÉV GARANCIA - Kártyafüggetlen, MS3972
