- ROG STRIX B660-F GAMING WIFI
- G.SKILL Trident Z5 RGB 32GB (2x16GB) DDR5 7200MHz
- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
