- SK Hynix 16GB DDR5 4800Mhz laptop ram több db!
- Bontatlan iPhone 17 Pro Max (256 GB) (rendelhető)
- Bomba ár! HP Probook 450 G10 - i3-1315U I 16GB I 256SSD I 15,6" FHD I W11 I Cam I Garancia!
- 0perces! Samsung Galaxy Book5 Pro 360 2in1 Core Ultra 7 256V 16GB 2TB 16" WQXGA+ AMOLED TOUCH 1évgar
