HookR
Gratulálok a nyereményhez!
"The world's second largest designer of x86 microprocessors will begin commercial shipments of its high-end FX-series chips based on Bulldozer micro-architecture in the second half of June and will initiate supplies of A-series code-named Llano accelerated processing units (APUs) in early July." - Xbit Labs
- AKCIÓS ! MacBook Pro 16" M1 Pro 16GB RAM 512GB SSD! 1 év garancia!
- Apple iPhone 14 Pro 128GB,Újszerű,Adatkabel,12 hónap garanciával
- Bontatlan! PlayStation 5 Slim Digital + kontroller 2 év garancia 2028.04.09-ig, számlával!
- Samsung Galaxy S21FE / 6/128GB / Kártyafüggetlen / 12Hó Garancia
- HIBÁTLAN iPhone 11 64GB White-1 ÉV GARANCIA - Kártyafüggetlen, MS4389, 100% Akksi
