- LG 27GR83Q-B - 27" IPS / QHD 2K / 240Hz & 1ms / NVIDIA G-Sync / FreeSync / DisplayHDR 400
- GYÖNYÖRŰ iPhone 12 Mini 128GB Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS3852, 100% Akksi
- 152 - Lenovo LOQ (15IRH8) - Intel Core i5-12450H, RTX 4060
- REFURBISHED és ÚJ - DELL Thunderbolt Dock WD22TB4 (210-BDTD)
- HIBÁTLAN iPhone 12 mini 64GB Green -1 ÉV GARANCIA - Kártyafüggetlen, MS3452,100% Akksi
