- Logitech G513 Carbon Tactile DE (3) (ELKELT)
- BESZÁMÍTÁS! ASUS H510M i3 10105F 16GB DDR4 512GB SSD GTX 1050Ti 4GB Thermaltake V3 fekete NBase 650W
- BESZÁMÍTÁS! MSI B450M R5 5600X 32GB DDR4 512GB SSD RTX 3070 8GB Zalman Z1 PLUS Cooler Master 700W
- QNAP TS-870U-RP 8 lemezes Rack NAS
- Bomba ár! HP EliteBook 845 G7 - Ryzen 5 4650U I 8GB I 256SSD I 14" FHD I Cam I W11 I Gari
