Archttila
Patice
#29296
Ezt most találtam:
Q,
I am planning to get the Asus Z97I-PLUS and wondering what should i buy, the Samsung SM951 256GB M.2 PCIe NVMe or the Samsung M.2 (2280) 850 EVO 500GB SATA SSD to plug it in the back of the borad m.2 slot and to install windows on this ssd.A,
If you buy the Z97I-PLUS don't plan on getting the full read/write speeds the SM951 is capable of because the M.2 slot located on the bottom of the board only supports PCIe 3.0 x2. I have the board currently and have checked the specs and other forums. You will still get good speeds around 700 or so. The M.2 EVO gets around 550 so speedwise you would want the SM951 and then upgrade your board later down the road. (There aren't many ITX boards that support the PCIe 3.0 x4). If you want more storage with decent speeds go for the EVO.Eléggé meggyőző az NVMe felület sebessége, de emiatt lapot cserélni...
majd pár év múlva amikor DDR4-re váltok
- Xiaomi Smart Band 8, Újszerű, 1 Év Garanciával
- BESZÁMÍTÁS! LENOVO Ideapad Gaming 3 notebook - R5 5600H 16GB DDR4 256GB +1TB SSD nVidia GTX 1650 4GB
- Apple iPhone 16 Pro Max 256GB, Kártyafüggetlen, 1 Év Garanciával
- GYÖNYÖRŰ iPhone 14 Pro Max 256GB Space Black - 1 ÉV GARANCIA, Kártyafüggetlen,MS3489, 100% Akksi
- OUKITEL G1 Mobiltelefon 24/256Gb dupla sim
