- HIBÁTLAN iPhone 14 128GB Red -1 ÉV GARANCIA - Kártyafüggetlen, MS3159, 100% Akksi
- ÚJ MSI Katana 15 HX - 15.6" QHD 165Hz - i5 14450HX - 16GB - 512GB - Win11 RTX 5050 - 3 év garancia
- Bomba ár! Dell Latitude E6220 - i7-2GEN I 8GB I 128SSD I 12,5" HD I HDMI I Cam I W10 I Garancia!
- BESZÁMÍTÁS! MSI B450M R5 5600X 32GB DDR4 1TB SSD RTX 4070 12GB Rampage SHIVA Cooler Master 750W
- BESZÁMÍTÁS! MSI B450M R5 5600X 32GB DDR4 512GB SSD RTX 4060 TI 16GB Rampage SHIVA A-Data 650W
