- 8x16 ddr4 vízhűtéses ram
- Bomba ár! Dell Latitude 3340 - i3-4GEN I 4GB I 500GB I 13,3" HD I HDMI I Cam I W10 I Garancia!
- GYÖNYÖRŰ iPhone 14 Pro Max 128GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS3915, 100% Akkumulátor
- Lenovo Thinkbook 16 G6 WUXGA IPS Ryzen7 7730U 16GB 512GB SSD Radeon RX Vega8 Win11 Pro Garancia
- Apple iMac 19.2 i5-8500 Radeon Pro 560X 4GB 16GB 256GB SSD 21.5" 4K Retina
