Osibaa
Egy kis érdekesség: Jetway J9F2-EXTREME
SpecifikációIntel 945GM+ICH7M chipset Technology
Support Intel Core 2 Duo Processor Up to T7600
Support Front Side Bus 667MHz
Support Mini PCI-Express x1
Dual Channel DDR2 667 Memory up to 2GB
Support 2 Serial ATA 2 Devices
Dual Gigabit Ethernet LAN Supported
6 Channel HD Audio CODEC
- MacBook Pro 16 M1 PRO / 16GB / 1TB ezüst
- 179 - 180 - 189 - 190 - Lenovo LOQ (15IRX9) - Intel Core i7-13650HX, RTX 4060
- Keresünk Galaxy S23/S23+/S23 Ultra/S23 FE
- 223 - Lenovo LOQ (15IRX10) - Intel Core i5-13450HX, RTX 5060
