Archttila
ATLAS - i5-6600K review
Most vagy ők bambák, vagy tényleg körülményes kicsit a hűtő szerelése.
Stock:
Well it seems that the AlpenföhnAtlas has redeemed itself (from that terrible install) posting one of the best Delta’s we’ve yet seen on our new Skylake platform. With a maximum Core temperature of 42 (21 Delta) degrees Celsius the Alpenföhn finds itself at the top of our chart (for now).OC:
Wow! I wasn’t expecting that! This little CPU Cooler really does seem to pack a 200W punch! Again we find the Alpenföhn CPU Cooler at the top of our (ok somewhat short) chart with a maximum CPU temperature of 58 (37 Delta) degrees Celsius and this time it shares the lead with no one! Of course in Gaming the temperatures will be even lower, and let’s be fair (as I’ve said many times before) who sits down for an evening of Prime 95 anyway!?Hűvösebb ház, Delid, 2x BQ 92mm FAN
már nagyon várom
