- Logitech G29 SE Driving Force PC/PS4/PS5
- LG 32UN880K - 32" IPS ERGO / 4K UHD / 60Hz 5ms / DisplayHDR 400 / USB Type-C / AMD FreeSync
- Apple iPhone 13 /128GB /Kártyafüggetlen / 12 Hó Garancia / akku: 85%
- BESZÁMÍTÁS! ASRock B450M R5 5500 16GB DDR4 512GB SSD RX 6600XT 8GB Zalman Z1 NEO ADATA 600W
- HIBÁTLAN iPhone 14 Pro 128GB Space Black -1 ÉV GARANCIA -Kártyafüggetlen, MS3590, 100% Akkumulátor
