HookR
Intel pushes standardization for all-in-one PCs
"Intel is cooperating with Taiwan-based all-in-one PC makers including Mitac International, Micro-Star International (MSI) and Elitegroup Computer Systems (ECS) to push standardization for all-in-one PCs and is planning to use Mini-ITX-format motherboards as a standard component of all-in-one PCs, according to sources from PC vendors.
The sources pointed out that because all-in-one PCs do not yet have a standardized platform, their design costs remain at a high level. and as Intel has already been working on setting up related specifications, they expect their costs for all-in-one PC development to drop significantly after the standard is out.
At CeBIT 2011, Mitac is showcasing its Maestro 650 all-in-one PC that adopts Mini-ITX motherboards based on Intel's standard, while MSI, ECS and Gigabyte Technology are also displaying Mini ITX motherboard-based all-in-one PCs at the show. Gigabyte is also set to launch the USB 3.0-based Mini-ITX motherboard GA-H55N-USB3 at the end of July."
Ó, de régóta várok már erre...
Kíváncsian várom, hogy belekukkanthassak.
- Kingston HyperX FURY RGB 32GB (2x16GB) DDR4 2666MHz (Beszámítás)
- ELADÓ: ASUS MAXIMUS VII Ranger LGA1150 alaplap - ritka, gyűjtői darab (+gari/számlás)
- HyperX Fury 3200Mhz 2X8GB Kit DDR4
- Hibátlan - CORSAIR Vengeance LPX 16GB (2x8GB) 3200MHz DDR4 CL16 memória kit
- PlayStation 5 FAT DIGITAL + kontroller 6 hó garancia, számlával!
- 27% - MSI Mag Coreliquid A13 360 ARGB
- Samsung QM55B 55" UHD 4K LED Signage Reklámmonitor 27% ÁFÁS
- Dell Latitude 7300 Core i5-i7, 8-16GB RAM, SSD, jó akku, számla, 6 hó gar
