Archttila
shteer
#30145
The Good:
tiny
very good to excellent voltage stability where it counts
very good ripple control
fully modular
excellent build qualityThe Bad:
nothing
The Mediocre:
line wire placement could be a problem for the fan on some of these
fan quality is an unknown quantity at this timeLehetseges emiatt gondolta, hogy ez akkor mar biztosan a szemet kategoria...
- BESZÁMÍTÁS! 32GB G.Skill Trident Z Neo RGB 3600Mhz DDR4 memória garanciával hibátlan működéssel
- Kingston FURY Beast 1x16GB DDR4 3200MHz (KF432C16BB1/16)
- Hibátlan - CORSAIR Vengeance LPX 16GB (2x8GB) 3200MHz DDR4 CL16 memória kit
- HyperX Fury 3200Mhz 2X8GB Kit DDR4
- 4x4Gb DDR4 2400Mhz XMP BALLISTIX RAM
- Apple iPad Air 2 (A1566) 64GB Wi-Fi Asztroszürke
- Lenovo ThinkPad P1 Gen 4 i7 32GB RAM 1TB SSD NVIDIA RTX A2000 2560X1600 400nit Garancia 19 hónap
- BESZÁMÍTÁS! ASRock A520M R5 5500 16GB DDR4 500GB SSD RX 5700XT 8GB Rampage SHIVA Seasonic 650W
- GYÖNYÖRŰ iPhone 13 128GB Red-1 ÉV GARANCIA - Kártyafüggetlen, MS4373, 100% Akkumulátor
- iPhone 15 Pro Max 256GB 89% (1év Garancia)
