- Corsair Vengeance 64GB (2x32GB) DDR5 6000MT/s CL40 XMP black kit - ÚJ, bontatlan, garis - ELADÓ!
- G.SKILL Trident Z Neo RGB 32GB (2x16GB) DDR5 6000MHz F5-6000J3238F16GX2-TZ5NR
- ÚJ HP Victus 15 - 15.6" FHD IPS 144Hz - Ryzen 5 8645HS - 16GB - 512GB - RTX 4050 - Win11 - 3 év gari
- Xiaomi Redmi Note 12 128GB, Kártyafüggetlen, 1 Év Garanciával
- Apple iPhone 14 Pro / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku : 87%
- 146 - 147 - 166 - 167 - 168 - 169 - Lenovo Legion Pro 7 (16IRX9H) - Intel Core i9-14900HX, RTX 4090
- BESZÁMÍTÁS! MSI B450 R5 5600X 32GB DDR4 512GB SSD RTX 3080 10GB Zalman Z1 Plus Cooler Master 750W
